Is is possible to use two servos on the Maqueen Plus? I am trying to code both the loader and forklift (on opposite sides of the robot) to move using two different servos and diffe...
userHead JaneYu 2020-11-20 02:13:32 93 Views4 Replies
Is is possible to use two servos on the Maqueen Plus? I am trying to code both the loader and forklift (on opposite sides of the robot) to move using two different servos and different buttons on the Gamepad. When I download the code to my microbit only one of the servos will work? Is the problem with my code or does the bot just not have enough power to do three things?
2021-08-28 21:42:04
Hello! Is there an extension in Mind+ for Maqueen Plus kit? I've found only Maqueen Lite extension.
2020-11-20 11:33:51
Hi Janae,
It's possible to use two servos on the Maqueen plus. Please make sure your board provides enough power for both servos. A 3.7V-18650 lithium battery is recommended for the power supply.
Let us know how it goes.
I tried to use the two servos on the Maqueen Plus MPEV. I am currently running into the problem of the servo for the Forklift attachment burning up. While I am using the recommended battery, could it be a power problem? I am also having a problem with the reaction time, to get the bot to move I have to hold down the button on the remote instead of being able to push it and have the bot react. If you have an example of the MPEV would you mind sharing it with me?
2020-12-02 22:59:20
