Hi, How Do I connect this to the Arduino MEGA2560 ? It works perfect on the UNO with the code provided but not the MEGA. please help ... thank you
userHead JaneYu 2020-12-10 03:57:14 107 Views4 Replies
2022-01-01 20:57:46
sucks that they don't have a datasheet available. Looks like the characters are built in and you cannot control each individual pixel.
There's a datasheet available for the STC 8F2K32S2. Looks like it takes in serial data and flips bits for the line drivers. Looks pretty straightforward to program. Good luck.
2022-10-30 18:21:41
2022-01-01 20:54:27
Did you look at the pinout? There's only 4 pins, +/- , serial in, serial out.
2021-01-30 23:42:26
Looking for a low profile RGB Dot matrix like this but I need it to be longer than this one. Do you have anything with a display that is about 2" x 18" 0r 20"?
