what would be the hardware required to read the data with a raspberry pi 4?
userHead JaneYu 2022-09-12 07:44:24 113 Views4 Replies
2022-09-27 09:49:43
Hi, May I please know what I could do to check if the sensor is working? I have tried and bought a multitude of devices in efforts to make this sensor work but have had no luck what so ever. I initially tried using it with a Raspberry Pi 3 along with a 2CH RS485 Hat in order to get something from the sensor, but no luck. I then tried using a USB to Rs485 adaptor still nothing. Then I decided to try out this sensor according to the Rs485 Arduino shield and an Arduino mega2560 R3, Still nothing. I ordered 3 of these sensors and have had no luck with any one of them. I made sure the sensor was getting the right voltage at all times. I also tried inverting the A/B cables after reading somewhere that manufacturers are not consistent with the wiring. Please let me know who I can talk to regarding this. Thank you.
Hi, Please contact our technical support email [email protected] and attach your wiring photo and code, thank you.
2022-10-19 15:31:33
2022-09-26 11:55:14
Hi, You can use the RS485 adapter module to connect to the Raspberry PI.https://www.dfrobot.com/product-102...
2022-02-18 15:50:28
Use RS485 to TTL module, then read data through ESP32
