I'd like to use this with the PI Arduino Shield (https://wiki.dfrobot.com/Ar.... Do you have any sample code and diagrams that show which pins on the shield to connect the pins on ...
JaneYu 2022-03-09 05:08:02 65 Views4 Replies I'd like to use this with the PI Arduino Shield (https://wiki.dfrobot.com/Ar.... Do you have any sample code and diagrams that show which pins on the shield to connect the pins on the ME007YS to?
As the same sensor is used in SKU:SEN0208 (https://www.dfrobot.com/pro... how could you claim this to be IP67 rated if you have commented to be not water immersible in its comments? (http://disq.us/p/209dpsa)
JaneYu IP67 refers to the sensor can be immersed in liquid for a short time will not break, does not mean that the sensor is suitable for immersion in liquid environment measurement, if you want to immerse the sensor in liquid level measurement, you can choose the input level transmitter.
Hi, IP67 refers to protection against short liquid immersion (immersion prevention) and does not mean prolonged underwater use.
Gravity: UART & I2C NFC Module DFR0231-H
