Hi there,I want to know that if there is any sensor for CO and NH3 that gives more than 3 V to a higher limit on its analog pin.Also if there is any module for the amplification lo...
userHead JaneYu 2022-03-14 20:10:45 104 Views3 Replies
Hi there,
Also if there is any module for the amplification low output voltage on Analog Output pin of these sensors?
2023-11-16 19:43:43
Does this sensor have hydrogen compensation?
This CO sensor does not have hydrogen compensation. If you have hydrogen up to 200ppm, it will have a 100ppm error effect on this sensor.
2023-11-17 09:03:22
2022-10-12 12:12:15
Thanks a lot for your respon and updating library.
