Is the sensing range really only to 2200 us/cm? Are you sure it's not 22000 us/cm?
userHead JaneYu 2022-05-18 07:35:42 31 Views13 Replies
2024-01-07 01:03:57
Can you please tell me a 3D model of this sensor? or maybe a drawing?
2023-12-20 01:11:45
Please answer
range is really 2200 us/cm or 22000 us/cm
It is very costly and range is very low ?
2023-12-13 03:08:01
Do you have any model, that might work with esp32 and i can use inside the pipes?
We apologize that we have not tested our library on the ESP32, if you need to use this sensor on the ESP32.
You can try by changing *5000/1024 to *3300/4096 in our sample code.
2023-12-13 10:00:09
2023-11-21 23:53:13
What are the dimensions of the sensor? What is the distance from the threads to the tip of the sensor? What is the type and size of threads?
2023-09-08 17:35:41
Hello, can I use this sensor with STM32 MCU?
2023-03-16 17:31:35
can this conductivity probe read values down of 100 μS/cm? For example 10, 20, 30, 25 μS/cm?
2022-12-29 02:33:35
Could you please tell us the tested range of this sensor.
Is it 2200 uS/cm2 or 22000 uS/cm2 ???
It's been a major confusion.
2022-11-09 06:01:30
Hello, could you give me information about product's Lifetime and maintenance of sensor.
2022-09-06 08:42:33
Hi, same question, isn't the measurement range 22000 uS/cm?, please your comments
2022-08-23 11:03:51
Can we measure soil conductivity using this probe?
Hi, no, this sensor can only measure the conductivity of liquids.
2022-08-23 11:08:45
2022-06-08 11:57:31
I have the same question as Xebediah. Isn't the measurement range 22000 uS/cm?
