Can these be used w/110V in an aluminum tube for heating a guitar neck?
JaneYu 2023-08-08 22:26:11 34 Views4 Replies Can these be used w/110V in an aluminum tube for heating a guitar neck?
2024-04-11 23:44:45
JaneYu
I'd like to use this element for a heater to heat some stuff. However, I'm confused about how to operate this.
To do that, the temperature controller (PID controller) and DC power supplier might be needed. Am I correct?
If you have the product for the temperature controller, could you please recommend it?
JaneYu JaneYu
wrote:
2024-04-12 11:41:11 1 Replies
This product does not have a temperature control function. As long as you power it on DC/AC 5V. This product can rise to 100℃ in 2~3 minutes
2023-03-31 23:27:17
JaneYu
You could add the product into the cart to check its wight.
This module is 0.01kg.
JaneYu
