Is there an english language version of the weikai wk2132-issg datasheet available?
JaneYu 2023-04-13 04:11:29 54 Views2 Replies Is there an english language version of the weikai wk2132-issg datasheet available?
Can this module handle UART to I2C communication while simultaneously performing I2C to UART? I am working on a project that requires sending data from UART to I2C, which then communicates with an I2C sensor. The sensor should then send back data via I2C to UART. Is it possible to perform both operations with this module, i.e., send and receive commands via UART and I2C simultaneously?
If this module is not capable of doing so, could you recommend another device that can fulfill this requirement?
JaneYu After contact with manufactor of the WK2132, they also donot have the English ver.
But they give us the English datasheet of WK2124 which we think you could refer to.
The WK2132 could use IIC UART SPI to lead out two UART interface.
While the WK2124 could only use SPI, but it could lead out four UART interface.
But the remaining parameters of these two ICs are basically the same.
https://github.com/YeezB/WK...
JaneYu
