Since the GPIO pins are the same on a Raspberry Pi Zero W is there any reason this wouldn't work on a Zero W? Obviously the screw connections won't match, but in terms of data/powe...
JaneYu 2023-06-19 02:13:01 31 Views2 Replies Since the GPIO pins are the same on a Raspberry Pi Zero W is there any reason this wouldn't work on a Zero W? Obviously the screw connections won't match, but in terms of data/power/etc.?
2023-10-27 00:37:49
JaneYu
Hello, I followed the tutorial on the Product wiki, it looks like it is accessing the SPI and attempting to transmit, however the received message is just all zeros. I am curious what OS is used for the tutorial? I am using the latest Raspberry pi OS and I have enabled the serial and SPI as instructed.
JaneYu 2023-06-29 17:20:05
JaneYu
This shield could be used on the Raspberry Pi Zero W, it's just that the volume is not reasonable, and the screw holes are not in the right position.
But it does not affect normal use.
JaneYu
