Hi.The product name has "1920x1280" but it has only 1080 vertical lines in the specification. What's "1920x1280" ?!And please list its mechanical drawings if you have a mechanical ...
userHead JaneYu 2023-09-29 13:14:22 103 Views5 Replies
Hi.
And please list its mechanical drawings if you have a mechanical drawing of the product.
2024-07-15 14:16:32
HDMI is capable of inputting audio and adapting signals. But it does not output touch signals. If you need touch, you need to connect to your board with Type-C CN2 connector.
2024-01-02 15:07:50
I understand, but poe standard have maximum limit of 25 watt. And they have options for 5 /20v as well so what matters is how much is the power consumption of the screen, if its still below 20 watt then its safe to pair it with pi devices , if its to high then poe is not feasible.
2023-11-15 16:50:19
Hello, I need a battery that is thin to be able to power the screen and a delta 3 lattepanda for a minimum of 5 hours of autonomy for a tablet project, what batteries can I use?
The battery needs to be selected according to your project.LattePanda 3 Delta supports 2 types of power supply, one is USB Type C port, support PD 15V power supply; the other is JST PH2.0 4pin port, support 12V power supply; 15.6 Inch 1920x1080 IPS Type-C Touch Screen & Display is powered by USB Type-C interface, supporting PD3.0, 5~20V power supply.
2023-12-04 14:12:22
2023-10-13 14:26:08
We have the 2D and 3D drawing for this screen , please find in the "Document" in this product page. Thanks!
