LattePanda V1 Fails to Auto Boot After Power Restoration
userHead Ashish_Epsilon 2025-03-26 21:09:35 2396 Views8 Replies
Hi all,
I'm using a LattePanda V1 running Xubuntu. I want the device to automatically power on when the power supply is connected, without needing to press the power button.
I have no control over shutting down the board properly — I can only turn the power supply on or off directly.
I have checked the BIOS settings and set "Restore AC Power Loss" to "Power On."
Sometimes, the device powers on as expected, but other times, it requires a manual press of the power button.
There is no consistent pattern — even with the correct BIOS setting, the device doesn’t always boot automatically.
I’m looking for a solution to ensure that the LattePanda V1 reliably powers on as soon as power is applied. Any insights or suggestions would be appreciated!
Thanks,
Ashish Upara
