Issue with Intel X710-DA2/DA4 on LattePanda MU Lite Carrier – Only One Port Active
userHead Jie.Zhang 2025-04-17 13:11:47 2563 Views7 Replies
We are planning to use the LattePanda MU in our crate control system. but I have encountered an issue when integrating the Intel X710-DA2 (dual-port) or X710-DA4 (quad-port) Ethernet adapters. Specifically, only the first optical port works, while the others report "cable unplugged" or fail to initialize.
System Configuration:
Platform: LattePanda MU (N100) + Lite Carrier
Ethernet Adapter: Intel Ethernet Network Adapter X710-DA2 (or X710-DA4)
Operating System: Ubuntu 24.04 / Windows 11
Problem Description:
Only the first optical port on the X710-DA2/DA4 works, and the others are not functional.
When testing on Ubuntu and Windows, the first port achieves full-speed operation, while the remaining ports report "cable unplugged."
The issue appears to be related to the BIOS configuration, as the BIOS recognizes only a single MAC address (the X710-DA2 should have two MAC addresses, and the X710-DA4 should have four). I have also noticed the following logs when run "dmesg | grep i40e":
[    8.590730] i40e 0000:04:00.1: failed to get phy cap., ret =  -EIO last_status =  OK
Findings and Troubleshooting Steps:
BIOS Configuration:
From the BIOS, it appears that only one MAC address is recognized for the X710-DA2. X710-DA2 should have two MAC addresses, and the X710-DA4 should have four, but only one is being initialized.
BIOS version: [DFLT]
I suspect that the issue may be related to how the PCIe lanes are allocated or a configuration setting in the BIOS.
Driver Loading:
I have verified that the i40e driver is loaded correctly, and the system recognizes both ports during boot. However, the second port fails to establish a connection (PHY initialization failure).
Power Supply:
I have confirmed that I am using a 12V power supply, and the power is stable. However, I am aware that the X710-DA4 requires PCIe x8 bandwidth, and the LattePanda MU's Lite Carrier may be limiting the available bandwidth to x4, but it could not contribute to the issue.
Questions:
Are there any known BIOS settings or updates that might address the issue of multi-port recognition for Intel X710 adapters on the LattePanda MU?
Could there be a limitation in the PCIe lane allocation that is causing only the first port to initialize properly?
Do you have any recommendations or fixes to ensure all ports on the X710-DA2/DA4 are functional?
I would appreciate any guidance or suggestions you can offer to resolve this issue.
Thank you for your support!
Best regards,
Jie
