ESP32S3 SD Card
userHead JR05 2025-04-27 21:39:01 1466 Views4 Replies
I am using esp32s3 board . Anyone tried to access sd card slot in the board ?
2025-05-25 01:12:02
#include "esp_camera.h"
#include "FS.h"
#include "SD.h"
#include "SPI.h"
// === Camera-Pin-Configuration ===
#define PWDN_GPIO_NUM     -1
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM     5
#define Y9_GPIO_NUM       4
#define Y8_GPIO_NUM       6
#define Y7_GPIO_NUM       7
#define Y6_GPIO_NUM       14
#define Y5_GPIO_NUM       17
#define Y4_GPIO_NUM       21
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM       16
#define VSYNC_GPIO_NUM    1
#define HREF_GPIO_NUM     2
#define PCLK_GPIO_NUM     15
#define SIOD_GPIO_NUM     8
#define SIOC_GPIO_NUM     9
// === SD-Card ===
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK  12
#define SD_CS   10
SPIClass spi = SPIClass(HSPI); // HSPI for SD-Card
  Serial.begin(115200);
  Serial.println("Start System...");
  // Init camera
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_SVGA;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  if (psramFound()) {
    config.fb_count = 2;
    config.grab_mode = CAMERA_GRAB_LATEST;
  if (esp_camera_init(&config) != ESP_OK) {
    Serial.println("Error Init Camera!");
    return;
  Serial.println("Camera ready.");
  // Init SD-Card
  spi.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
  if (!SD.begin(SD_CS, spi)) {
    Serial.println("Error on Init SD-Card!");
    return;
  Serial.println("SD-Card ready.");
  // Wait 30 Seconds
  Serial.println("Wait 30 Seconds...");
  delay(30000);
  // Zeitstempel (mit millis() oder RTC)
  unsigned long now = millis();
  int ms = now % 1000;
  int sec = (now / 1000) % 60;
  int min = (now / (1000 * 60)) % 60;
  int hour = (now / (1000 * 60 * 60)) % 24;
  int day = 1;
  int month = 1;
  int year = 2025;
  char filename[32];
  snprintf(filename, sizeof(filename), "/%04d%02d%02d_%02d%02d%02d%03d.jpg",
           year, month, day, hour, min, sec, ms);
  // Take Picture
  Serial.println("Take Picture...");
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Error on take picture!");
    return;
  // Save Picture on SD-Card
  File file = SD.open(filename, FILE_WRITE);
  if (!file) {
    Serial.println("Error on save picture on SD-Card!");
  } else {
    file.write(fb->buf, fb->len);
    file.close();
    Serial.print("Saved Picture as: ");
    Serial.println(filename);
  esp_camera_fb_return(fb);
  Serial.println("Process done.");
  // Nothing to do
userHeadPic Lupin
2025-04-28 02:55:30
Did you check this video?
userHeadPic ahsrab.rifat
2025-04-27 21:43:09
I am using this board
https://wiki.dfrobot.com/SKU_DFR1154_ESP32_S3_AI_CAM#target_9
userHeadPic JR05
ahsrab.rifat wrote:
Though your board is different, you can get help from this: https://dronebotworkshop.com/esp32-cam-microsd/
2025-04-28 19:54:48
