Build a clustering computer using multiple LattePanda-mu (N305)
Jason.Lee 2025-04-28 23:11:18 2482 Views2 Replies What would be the best way to build a clustering computer using lattePanda Mu?
Should I use a career board for each LattePanda Mu module and clustering with Ethernet? In that case, should I use power adapter for each career or could be a larger PSU to provide a power?
Or is there any clustering career board for 5 or 10 of Latter Panda Mu?
Any suggestion?
When building a cluster with LattePanda Mu modules, it’s recommended to use one carrier board per module and connect them via Ethernet. For power, you can either use separate power adapters for each board or a single larger power supply to handle multiple boards. If choosing the latter, make sure it delivers enough voltage and current for all connected modules.
For deeper insights or questions, check out the LattePanda community forum: https://www.lattepanda.com/forum/.
JaneYu Thanks Tonny12138
appreciate your insight
