RS485 Wind Vane Direction Sensor Always Return 0
Md Jahidul Islam.Rahat 2025-05-02 01:17:15 1433 Views1 Replies I bought a DFRobot RS485 Wind Vane Direction Sensor, but the sensor is not working properly. When I try to read data through Modbus, it always returns 0. I tried your Arduino library as well as writing my own code, but I’m always getting 0 from the sensor. What should I do right now? Here is my code and the datasheet that you sent me. I supplied 12V to the sensor, and the connections are correct.
// const uint8_t request_frame[] = { 0x02, 0x03, 0x00, 0x01, 0x00, 0x01 };
const uint8_t request_frame[] = { 0x02, 0x03, 0x00, 0x00, 0x00, 0x01 };
20:19:10.324 -> Wind Angle: 0
20:19:11.324 -> Request: 02 03 00 00 00 01 84 39
20:19:11.355 -> Response: 02 03 02 00 00 FC 44
20:19:12.329 -> Wind Angle: 0
20:19:13.326 -> Request: 02 03 00 00 00 01 84 39
20:19:13.359 -> Response: 02 03 02 00 00 FC 44
20:19:14.356 -> Wind Angle: 0
20:19:15.352 -> Request: 02 03 00 00 00 01 84 39
20:19:15.352 -> Response: 02 03 02 00 00 FC 44
20:19:16.348 -> Wind Angle: 0
