Gravity Geiger Counter (V1.0.0) - Connector Part Number
erikholindrake 2025-05-03 02:38:37 1140 Views2 Replies What is the part number (and/or mating part number) for the Gravity Geiger Counter. The kit did not come with it. Thanks!
2025-05-05 16:22:21
ahsrab.rifat
If your kit did not include the necessary cable, you can use a Gravity 3-pin sensor cable or a standard JST-XH 3-pin to DuPont female jumper cable to connect the module to your microcontroller. These cables are widely available and compatible with various development boards.
ahsrab.rifat Yeez_B
wrote:
2025-06-04 09:49:40 1 Replies
The connector is JST PH2.0 3pin instead of JST XH2.54.
