are there modbus commands to calibrate the SEN0603?
userHead Jeff.Tucker 2025-05-17 00:20:39 1094 Views2 Replies
2025-05-20 10:38:34
The SEN0603’s EC and pH calibration are both performed via Modbus “Write Single Register” (Function Code 0x06). The relevant registers are:
EC Calibration Register
Address: 0x0052
Modbus Register Number: 40083
Access: Read/Write
Usage: Write an integer value to set the new EC calibration constant.
pH Calibration Register
Address: 0x0053
Modbus Register Number: 40084
Access: Read/Write
Write an integer value to set the new pH calibration constant.
To calibrate, simply send a Function 0x06 request targeting 0x0052 (for EC) or 0x0053 (for pH) with the desired integer value. After writing, you can verify the stored value by issuing a “Read Holding Registers” (Function 0x03) request to the same register.
2025-05-20 10:38:40
