How to select
Pressure sensor for sea water (SEN0257 or KIT0139) ?
userHead BennyNakai 2025-05-22 22:14:38 1133 Views1 Replies
Hello.
I need to measure pressure in sea water.
I have a water-tight tank with all electronics inside and i can drill a hole to place a pressure transducer partially outside.
will the SEN0257 or KIT0139 fit my needs ?
2025-05-23 13:04:39
Given your requirements, KIT0139 may be more suitable for measuring pressure in sea water, especially if you need a sensor that can be submerged and withstand the corrosive nature of sea water.
