Object ID is always zero in Huskylens object recognition mode
PIERRE.GAUTHIER 2025-06-09 11:45:40 1289 Views1 Replies I have a problem detecting an object with Huskylens in object recognition mode.
I want to detect if the object is a ‘person’. It is one of the standard objects Huskylens
can detect.
My Huskylens firmware version is 0.5.1aNorm.
I use a Raspbery Pico 2W connected to the Huskylens via I2C.
Communication with the Huskylens is fine, no error message.
I use the huskylensPythonLibrary.
Here's some sample code I use:
husky = HuskyLensLibrary("I2C")
husky.command_request_knock()
husky.object_recognition_mode()
for i in range(1000):
result = husky.command_request()
print("======================================")
for res in result:
print(res)
time.sleep(1)
This is the output when no object is detected:
before finalData, ['55aa', '11', 10, '29', '00000100442400000000', 'ac']
numberOfBlocksOrArrow= 0
numberOfIDLearned= 1
frameNumber= 9284
Output when a “person” object is detected:
before finalData, ['55aa', '11', 10, '29', '01000100742400000000', 'dd']
numberOfBlocksOrArrow= 1
frameNumber= 9332
commandSplit 2= ['55aa', '11', 10, '2a', '0501bd004f0058000000', 'ae']
<class 'list'>
55aa
11
10
2a
ae
<class 'list'>
[261, 189, 79, 88, 0]
I believe the last line [261, 189, 79, 88, 0] is the X,Y, width,height, object ID data
but the object ID is always zero. I can see on the Huskylens display that it can detect
a person, a cat etc but the id is always zero.
Is this a bug or is there something I'm not doing right? I saw some other people having the
same issue. There must be a way to determine the type of object recognized by Huskylens
Thanks for your support.
Pierre
Sorry, I have finally solved my problem.
By the way, I use the Raspberry Pico micropython library (with an example) from this link:
https://community.dfrobot.com/makelog-311712.html
I needed to put the Huskylens in learn mode first. So I trained it with the code
below. I thought that because the Huskylens recognizes some objects by default (ex. person, cat etc)
I didn't need to train it first.
#train Huskylens to recognize a person, set ID to 1.
#In this case I train Huskylens to assign ID 1 to a person
print("object recognition command")
#set ID to 1
husky.command_request_learn_once(1)
time.sleep(1)
After learning, I ran the normal code:
print("knock command")
print("request command")
for res in result:
print(res)
time.sleep(1)
and I can now see the ID1 I expected along with the X,Y, width,size:
<class 'list'>
[110, 158, 55, 144, 1]
I also verified that it can detect multiple persons, so I will get multiple [X,Y,width, height,ID] in the command response.
PIERRE.GAUTHIER
