TroubleshootingMind+
OLED extension for ESP8266
userHead Muffin.Liu 2025-07-08 15:04:37 1487 Views3 Replies
Hi all, I have hopefully a quick question, any advices or helps would be much appreciated!
I am trying to find a mind+ extension that makes OLED and ESP8266 work together, but I failed so I am developing the extension myself and I am pretty new to this. I tried u82g library and developed the extension according to the required format, however, I am getting a bunch of “…undefined reference to….” error when I compiled a sample code that uses this extension. Below is the code being compiled, it seems no problem to me:
#include <U8g2lib.h>
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
// Main program start
u8g2.begin();
 u8g2.setFont(u8g2_font_ncenB08_tr);
  u8g2.setFontDirection(0);
u8g2.setCursor(0, 0);
u8g2.print("hello");
u8g2.sendBuffer();
I am not able to attached the entire extension because of the file size. Below is the error I am getting:
/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text._ZN4U8G25writeEh[_ZN4U8G25writeEh]+0x0): undefined reference to `u8g2_DrawGlyph'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2::write(unsigned char)':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:331: undefined reference to `u8g2_DrawGlyph'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x4): undefined reference to `u8g2_font_ncenB08_tr'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x10): undefined reference to `u8x8_InitDisplay'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x14): undefined reference to `u8g2_ClearDisplay'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x18): undefined reference to `u8x8_SetPowerSave'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x1c): undefined reference to `u8g2_SetFont'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x20): undefined reference to `u8g2_SetFontDirection'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.setup+0x24): undefined reference to `u8g2_SendBuffer'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `setup':
C:\Users\hange\AppData\Local\DFScratch\cache/dfrobot.ino.cpp:13: undefined reference to `u8x8_InitDisplay'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2::initDisplay()':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:119: undefined reference to `u8g2_ClearDisplay'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2::setPowerSave(unsigned char)':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:130: undefined reference to `u8x8_SetPowerSave'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2::setFont(unsigned char const*)':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:269: undefined reference to `u8g2_SetFont'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2::setFontDirection(unsigned char)':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:271: undefined reference to `u8g2_SetFontDirection'
C:\Users\hange\AppData\Local\DFScratch\cache/dfrobot.ino.cpp:19: undefined reference to `u8g2_SendBuffer'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache/dfrobot.ino.cpp:21: undefined reference to `u8x8_ascii_next'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.startup._GLOBAL__sub_I_u8g2+0x18): undefined reference to `u8x8_utf8_init'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o:(.text.startup._GLOBAL__sub_I_u8g2+0x1c): undefined reference to `u8g2_Setup_ssd1306_i2c_128x64_noname_f'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `Print::Print()':
C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\esp8266\cores\esp8266/Print.h:46: undefined reference to `u8x8_utf8_init'
c:/program files (x86)/mind+/arduino/hardware/tools/esp8266/xtensa-lx106-elf-gcc/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\hange\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o: in function `U8G2_SSD1306_128X64_NONAME_F_HW_I2C::U8G2_SSD1306_128X64_NONAME_F_HW_I2C(u8g2_cb_struct const*, unsigned char, unsigned char, unsigned char)':
C:\Users\hange\AppData\Local\DFScratch\extensions\keithliu-rocketkit-thirdex\arduinoC\libraries\Keith_SSD1306/U8g2lib.h:1696: undefined reference to `u8g2_Setup_ssd1306_i2c_128x64_noname_f'
Link error
Any helps on fixing the code, or link to existing extension would be very helpful!
2025-07-17 18:06:59
Any existing extension that allow me show text on an I2C connected OLED with ESP8266 will help me too. Any helps would be much appreciated!
userHeadPic Muffin.Liu
2025-07-15 02:13:45
To test whether the issue is from your extension setup or the library itself, do this:
Open the Arduino IDE.
Go to Tools → Board → Select your ESP8266 board (like NodeMCU or Wemos D1).
Go to Sketch → Include Library → Manage Libraries.
Search for U8g2 and install the official one by Oliver Kraus.
Copy-paste your test sketch again:
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
 u8g2.begin();
 u8g2.setCursor(0, 10);
 u8g2.sendBuffer();
If this compiles and uploads to your ESP8266 in Arduino IDE — the library is fine, and the issue is with your Mind+ extension setup.
userHeadPic ahsrab.rifat
Muffin.Liu wrote:
Thank you for replying ahsrab.rifat
Yes, I tried it on Arduino IDE and it works. I am quite sure that there is something wrong with the extension and am trying to figure what wrong is it.
2025-07-17 18:02:39
