No matter whether a object is placed or not, the sensor output data is always 0.
JaneYu 2024-07-11 14:51:30 509 Views0 Replies No matter whether a object is placed or not, the sensor output data is always 0.
2024-07-11 14:51:30 This is caused by placing the object on the scale before the Arduino completes the reset. Solution: Take off the object on the scale, press the reset button of Arduino or the rst button of the sensor, and put the object on again, then it can be used normally.
JaneYu
JaneYu
