why the SD indicator is not lit when data is rapidly written to the module.
JaneYu 2024-07-11 00:46:45 591 Views0 Replies The SD indicator is not lit when data is rapidly written to the module.
2024-07-11 00:46:45 The SD card has write endurance cycles of 100 thousand times. In order to ensure the SD life, write to SD card once about 50ms or 512 bytes after the module writes to data.
JaneYu
JaneYu
