And when will the module enter USB flash drive mode? When to enter data storing mode?
userHead JaneYu 2024-07-11 22:14:44 1107 Views0 Replies
When will the module enter USB flash drive mode? When to enter data storing mode?
2024-07-11 22:14:44 When a USB host is used to connect the module, the module enters the USB flash drive mode, at the time data can't be stored in the module and the CONFIG.TXT file and new blank files will not be automatically generated when the module is powered on. In other cases, the module enters the data storing mode, and the CONFIG.TXT file and new blank files will be generated automatically if the module doesn't have a CONFIG.TXT file. userHeadPic JaneYu
