FireBeetle+GDI screen not working? Check connections, power, and code config.
JaneYu 2024-07-11 00:53:33 924 Views0 Replies FireBeetle+GDI screen not working? Check connections, power, and code config.I'm using a FireBeetle with a GDI connector with the FPC cable that came with the screen to drive the screen. But after uploading the sample code I am not able to get a valid display.
2025-07-24 14:53:20
JaneYu
The metal contacts of the FPC flex cable need to face the white part of the GDI connector.
If you are not sure about the orientation of the FPC and GDI ports, you can try it by reversing the connection. The FPC cable is protected by reverse connection, so you don't have to worry about taking the risk of burning the screen or the GDI port.
JaneYu
