Check compatibility, voltage, and signal protocols when pairing with other receivers.
userHead JaneYu 2024-07-11 11:19:26 582 Views0 Replies
What should be noticed when using this self-powered wireless switch with receivers from other manufacturers?
2024-07-11 11:19:26 You need to pay attention to whether the receiver supports EV1527 decoding and 10Kbps rate. EV1527 encoding and 10kbps is a very common standard. userHeadPic JaneYu
