How to use the onboard micro-SD card slot?
JaneYu 2024-07-11 08:42:58 554 Views0 Replies How to use the onboard micro-SD card slot?
2025-07-24 14:59:56
JaneYu
Use it as the normal one using Arduino SD library is ok. Note that because the W5100 and SD card share the SPI bus, only one can be active at a time. For more, please check on Arduino, Arduino Ethernet Shield.
JaneYu
