How to set the IP address?
userHead JaneYu 2024-07-11 11:06:54 543 Views0 Replies
2024-07-11 11:06:54 Open your Network connection properties, and check the IPv4 Address and Gateway. The first three numbers should be set as same as on your board. The last number can be any number between 0-255, as long as it is not occupied by any other devices. userHeadPic JaneYu
