Space/cost efficiency - resistors handle fixed bits while switches manage key address bits.
userHead JaneYu 2024-07-11 21:37:26 793 Views0 Replies
Why do I need to solder resistor to adjust the lower four bits of the I2C address, instead of also designing more dip switch to adjustment other bit?
2024-07-11 21:37:26 Dip Switch schange the address by connecting a large number of resistors in parallel or not. If the lower four bits are also use the dip switch, this will greatly increase the number of resistors on board.This makes the size of this module very large. userHeadPic JaneYu
