My LED strip turned on yesterday, but will not turn on today. Why?
userHead JaneYu 2024-07-11 14:54:08 510 Views0 Replies
2025-07-24 15:16:23
1) Check your code and circuit connections
2) Check your LED strip has adequate power (5V@3A for 3 meters)
3) If you can find no solution, find the end of the strip connected to your microcontroller. Desolder the -, + and s lines from the end of the LED strip, cut off the end LED and then solder the connections to the next LED along.
