Program with SD library prevents serial monitor output"
userHead JaneYu 2024-07-11 12:51:22 3263 Views0 Replies
When using the SD library, the serial monitor does not show any print output or displays a connection failure after uploading the program.
2024-07-11 12:51:22 Press RST button to reset and try again. userHeadPic JaneYu
