The driver is not installed automatically after plugging into the device?
JaneYu 2024-07-11 06:02:38 580 Views0 Replies The driver is not installed automatically after plugging into the device?
2025-07-24 15:26:13
JaneYu
FireBeetle 2 ESP32-E uses the CH340 serial chip, which can be used without installing a driver in most devices. If you find that the driver is not automatically installed when you plug in the device, you can manually install it yourself:
JaneYu
