How to measure the soil moisture?
userHead JaneYu 2024-07-11 06:54:01 555 Views0 Replies
2024-07-11 06:54:01 Soil moisture is defined as: Get 1 kg soil samples, thoroughly dry it, the ratio between reduced weight (water weight) and 1 kg weight is soil moisture. It totally different to the air humidity. userHeadPic JaneYu
