Can I connect two battery to each of the BAT IN connectors?
userHead JaneYu 2024-07-11 10:10:07 860 Views0 Replies
2024-07-11 10:10:07 Yes. But pay attention that these two batteries are in direct parallel connection. It is required that these two batteries are of the same (or near) specifications. The two connectors are designed to be compatible with more battery interfaces. Usually, pick one to connect a single Li battery. userHeadPic JaneYu
