Battery installed, power light on, but motor won't respond?
userHead JaneYu 2024-07-11 21:03:54 705 Views0 Replies
Hello, after installing a battery in the car, the motor still can’t be controlled to rotate by burning program while the power light is on?
2024-07-11 21:03:54 Perhaps the battery is dead, and it is recommended to replace it with a fully charged one. When the battery voltage is lower than 2V, the LED on the board and other functions can work normally, but the motor can’t rotate due to insufficient power. userHeadPic JaneYu
