Light dim/partial after uploading sample code - why?
userHead JaneYu 2024-07-11 13:56:36 738 Views0 Replies
Why sometimes the light is partially lighted/ the brightness is low when the sample code is uploaded?
2024-07-11 13:56:36 The light ring requires a high power supply. So you need to connect the USB cable or the external battery to power port(USB/ external battery) of the expansion board. userHeadPic JaneYu
