Why doesn't the motor rotate?
JaneYu 2024-07-11 05:35:05 689 Views0 Replies Why doesn't the motor rotate?
2025-07-24 16:11:01
JaneYu
1, First check the power supply, VIN power supply is required, the VM indicator on the expansion board lights up.
2, Then check if there is a problem with the program, you can remove other programs and only test motor control.
JaneYu
