Is it possible to use Arduino D4 to control Relay 1?
userHead Schultz.Langley 2024-07-25 10:45:57 811 Views1 Replies
2025-07-25 11:08:36
It's easy to make it just by removing the jumper on the board and then connect the pin of Relay1 to any Digital pin you need.
For A4. Xbee pin attached with Relay control pinFor A4. Xbee pin attached with Relay control pinFor A4. Xbee pin attached with Relay control pinFor A4. Xbee pin attached with Relay control pin
https://raw.githubusercontent.com/DFRobot/DFRobotMediaWikiImage/master/Image/Relay_Shield_DFR0144_sch_for_xbee.png
userHeadPic Schultz.Langley
