Lattepanda Delta 3 "auto power on" / AcPowerLoss - Power On doesn't work
userHead StefanXP 2025-07-25 22:37:15 1483 Views2 Replies
I made sure the RTC battery's charge is ok, it was not connected before.
In the documents you stated, that the Auto Power-On should work even if the RTC Battery is depleted..
I reset the BIOS Settings to Default Settings.
I set up the Auto Power On like here: https://docs.lattepanda.com/content/3rd_delta_edition/bios_Auto_power_on/
I made sure, that https://docs.lattepanda.com/content/3rd_delta_edition/bios_Deep_Sleep_EUP_Support/ is disabled
I Use Windows 10 on the Latte Panda.
I think it should take less then 30s from pressing SW1 to showing Latte Panda Logo.
I made sure, that the BIOS ROM: S70JR230-8G-A_20250416093826.bin of Build Date: 2025/4/16 is installed.
I checked the Serialnumber of the specific Latte Panda Delta 3 and its S70JR210.
Please let me know if you have further suggestions.
Best regards, Stefan
2026-02-13 14:02:22
Hello Stefan, please contact techsupport@lattepanda.com for A/S service.
userHeadPic LattePanda
