Unihiker k10 unable to enter wifi config mode
mnghhl 2025-08-21 10:54:37 2572 Views3 Replies I wanted to flash it using the xiaozhi firmware (https://community.dfrobot.com/makelog-317317.html).
After I reset, what I get is only a black screen with some clicking sound. Is my newly bought k10 faulty?
2025-09-08 18:09:27
Mr.Harry
To enter WiFi config mode on the Unihiker K10, try pressing and holding the reset button for about 10 seconds until the indicator light starts blinking or changes color. If that doesn't work, you may need to check the manual for specific instructions, as some models may require a different button combination or process to access the WiFi settings. Also, ensure the device is powered on and within range of your network.
Mr.Harry
