ArduinoTroubleshooting
Sound Sensor Module Giving Flat Readings
userHead Jordan.Miller 2025-09-04 05:16:44 896 Views2 Replies
Hi everyone,
I’m working on a noise-detection project using the a Sound Sensor Module. The goal is to trigger a buzzer when audio levels exceed a certain threshold.
Here’s what’s happening:
I’ve wired VCC → 5V, GND → GND, and OUT → a digital pin on my Arduino. When I test, the output value barely changes, even with loud noise; it’s either stuck HIGH or LOW most of the time. I’ve adjusted the on-board potentiometer, but it still doesn’t respond reliably.
Tried with both digitalRead and analogRead, same result, no variation. From what I’ve seen in other threads (e.g., on Arduino forums), these modules can have a very narrow detection threshold and be sensitive to noise, grounding, or even power level changes.
Questions for you all:
Is flat or stuck output behavior typical if the threshold isn’t set just right? Would powering with 3.3V instead of 5V help with sensitivity or signal stability? Should I add a pull-down resistor or extra filtering on the signal line? I’d really appreciate any advice or tips on how to get this sensor behaving properly.
Thanks a lot!
-Jordan
2025-11-24 11:57:02
Flat/stuck output is common if the threshold’s off. Calibrate the pot, add analog smoothing (moving average), try a 10–100k pull-down, decouple VCC with caps, and test 3.3V for sensitivity changes. For trending sounds [soundboard](https://soundboardw.com/) download at SoundBoardW.com.
userHeadPic SoundBoardW.Com
2025-09-05 02:24:42
You can use Analog / AGC microphone modules (e.g., MAX9814 or INMP441 [I²S]) that  give a clean analog envelope or digital audio and better SNR than cheap modules. MAX9814 modules with onboard AGC are great for amplitude detection.
If you must keep the cheap sensor, wire AO → envelope detector → Arduino A0 and use the code above.
userHeadPic ahsrab.rifat
