DF2301QG V1.0 Skips to done when esp enters loop Issues
Iyoaye.David 2025-09-12 14:44:36 1251 Views3 Replies so i noticed my voice recognition sensor always goes “ you are welcome to” and then it immediately skips to ‘done’ when the i2c connects in the loop. the volume noticeably drops by a lot not sure if that affects other things . i tried putting a delay at the end of the end of the setup codes, didnt work. is it only me or its general. using ESP 32s3. for clarity if there if i do not communicate with a controller it works fine.
PS too. i had to change to a modified library on github this year. the original was causing a panic to the controller with a firebase some other code at the time
The volume drop suggests that the playback chip on the voice module might lose proper gain control or clock sync when the ESP32 bus activity spikes.
ahsrab.rifat okayyy. how doi fix that
.jpg)
