Unihiker Not Recognized After MicroPython Firmware Update (Shows as Generic ESP32)
userHead Mariana.Barbosa 2025-09-13 06:05:17 2380 Views4 Replies
Hello everyone,
I'm facing an issue after updating my Unihiker board and I'm hoping someone here might have some advice.
I've flashed the latest micropython firmware version (unihikerK10mpy_20250813_V1.0.bin). However, after the update, when I connect the board to my PC to use with Thonny, it's only recognized as a generic ESP32 device, not as a Unihiker board.
I have already tried to solve this by reinstalling the firmware multiple times using two different methods:
1. On Fedora KDE, using the recommended online ESP LaunchPad tool.
2. On Windows 11, using the official Flash Download Tool.
Unfortunately, the problem persists in both cases.
Has anyone experienced this before or have any suggestions on what I could try next?
Thank you in advance for your help!
2025-09-15 09:59:00
Since the MicroPython firmware is still under development and currently in early access, we have not applied for a specific identifier for the K10. In Thonny, the K10 is still recognized as a generic ESP32, but this does not prevent you from calling any K10-specific libraries within Thonny.
userHeadPic Yeez_B
Mariana.Barbosa wrote:
Thanks =)
2025-09-16 00:34:43
2025-09-14 02:19:33
USB devices are identified by Vendor ID/Product ID + possibly USB descriptors. If the firmware you flashed resets those identifiers (or doesn't include the Unihiker-specific USB descriptor), then the OS will show it as a generic ESP32 product.
userHeadPic ahsrab.rifat
Thanks for the reply =)
2025-09-16 00:34:56
