ESP32 C mini didn't boot up
userHead Phuvis.Komutmas 2025-09-24 14:50:08 1209 Views3 Replies
I use esp32 c6 mini in my IOT project. At first, it works normally when I use it with LiPo battery 3.7v but then Its blackout and didn't boot up when I power it. I use my multimeter to check that is power is normally with bat pin and it seem normal. And 3.3v pin can still use. Did it have another way to check where the problem is? or it already broken. ๐Ÿ˜ž
2025-09-26 02:48:59
Measure battery voltage at the battery terminals (or the board BAT input).
LiPo nominal 3.7 V, full 4.2 V, not healthy if < 3.0 V.
If < 3.0 V,  battery is discharged or protection kicked in โ€” recharge battery. If it falls quickly under any load the battery is weak.
userHeadPic ahsrab.rifat
Phuvis.Komutmas wrote:
I just see your reply. Yes I check the battery
2025-11-08 11:14:52
And I found that Battery swelling. Appreciate for your reply.
2025-11-08 11:15:46
