DFR0760 speech module to PC
Richard.Hutchinson 2025-09-25 17:52:22 783 Views1 Replies I'm trying to connect the module (V2.2.0) to a PC
I have it connected to a USB-serial adapter (which is also powering the module)
Using terminal software configured to 115200 baud 8n1
Sending the string - [h2]this is a test
Nothing happens
Please advise ?
2025-09-28 00:11:27
ahsrab.rifat
What’s the power requirement of the module? Some USB-serial adapters don’t supply enough current (often <100mA). For Wi-Fi/Bluetooth modules, you may need a separate regulated 3.3V supply.
ahsrab.rifat
