SKU: SEN0644, how can I determine the LUX illumination acquisition rate?
userHead Om Thakre 2025-10-01 14:01:41 641 Views1 Replies
what is the meaning of Levels 1–20, and how can I properly read from and write to the sensor?
2025-10-04 12:41:04
You need to communicate with the sensor (RTU) over RS-485 using MODBUS.  Using a computer, download Simply Modbus Master and connect the sensor via an RS-232 or USB-to-RS-485 adapter.  See the SEN0644 wiki page on registers; you need to write to the configuration registers of interest using Modbus.
userHeadPic K0I05
