Calibration of DFRobot Sensors (pH, EC, and Dissolved Oxygen)
rawr 2025-10-08 18:37:16 939 Views0 Replies Is it possible to calibrate the sensors in Arduino (using the open source code in DFRobot site) and then use these sensors in Raspberry Pi? Will the calibration parameters be the same? Thank you.
Note: I will also use DFRobot's ADS1115 board for ADC
Raspberry Pi ProductsRaspberry Pi ProjectsView Arduino ProductsMore Arduino Related ProjectsArduino TutorialsMore Gravity ProjectsView Gravity Products
