SEN-000010-000 flow sensor
userHead Jordan.Miller 2025-10-20 23:44:20 128 Views0 Replies
Hey everyone,
I’m working on a DIY project where I need to measure water flow (for a small tank + pump system) and came across the SEN-000010-000 . It reports pulses based on flow rate, which sounds perfect for my microcontroller setup. Since I’m still groping through sensors and wiring, I wanted to ask:
How accurate is it in real use? Did you need to calibrate it experimentally for your setup?
Does it handle variations in water temperature or bubbles well, or do those mess up the readings?
Any wiring/layout tips: How did you interface the pulse output to your MCU (interrupts, debouncing)?
If anyone here has used this sensor (or a similar one) in a real system, I’d love to hear how you set it up and any surprises you found. Thanks in advance!
