Trouble Adjusting SEN0158 Camera Sensitivity — Laser Reflection Not Detected
userHead Nick.Bender 2025-10-21 10:23:03 669 Views3 Replies
Hi everyone,
I’m having some trouble with my SEN0158 camera. It doesn’t seem to detect the laser reflection even from a projector screen surface at a distance of about 2–3 meters. I’ve already tried repositioning the laser and adjusting lighting conditions, but no luck so far.
I reached out to support for help with tuning the camera’s sensitivity, but haven’t received a clear response. Does anyone here know if there’s a way to manually adjust the sensitivity or analog gain of the SEN0158? Maybe through firmware settings or any external configuration tools?
Any suggestions or experience with improving the camera’s reflection detection would be greatly appreciated!
Thanks in advance,
2026-04-01 21:39:41
It sounds like a sensitivity calibration issue—adjusting thresholds or checking environmental interference might help improve detection. Interestingly, just like fine-tuning sensors for accuracy, optimizing everyday tools like the Albert Heijn AH Bonuskaart helps you detect the best deals and save more efficiently.
userHeadPic noha.Noha
2026-01-31 15:46:17
Sensitivity issues with the SEN0158 camera can be tricky, especially when laser reflections are weak or affected by ambient light and surface properties. Proper calibration, controlled lighting, and clear documentation of test results can really help during troubleshooting. When sharing setup notes, calibration steps, or test outputs, using a simple pdf printer test page can be useful to ensure diagrams and logs are clearly formatted and easy to review. Accurate documentation often makes hardware debugging much easier.
userHeadPic Rose.Eve
2026-01-27 18:52:00
“When adjusting camera sensitivity and dealing with laser reflection detection issues, precise measurements and parameter tuning are key. Using tools like the Texas Instruments TI-84 Plus Graphing calculator can help with quick calculations, threshold adjustments, and analyzing sensor data during testing and calibration.”
userHeadPic anne.joan
