SEN0211 voltage output range documentation
Jdavis22 2025-11-06 22:23:25 679 Views1 Replies Can someone explain the circuit on SEN0211?
https://wiki.dfrobot.com/Gravity_Analog_AC_Current_Sensor__SKU_SEN0211_
has this text
Interface: Gravity Analog (PH2.0-3P,analog voltage output 0.2-2.8VDC)
I do not see the .2 offset when there is 0 current flowing. I see close to 0 volts. I'm using a 3.3v power source.
Is the Doc wrong or do I have a bad board or ?
Hi Jdavis22! It sounds like you’re facing an interesting issue with the SEN0211 sensor. It’s crucial to ensure that your connections and power supply are solid. Sometimes, offset discrepancies can occur due to calibration. If you're looking for different ways to handle those voltage variations in projects, you might want to check out something like ** for inspiration. Hope you find a solution soon!
Lincoln.Wynne
