RainbowLink 4-channel USB to Serial Converter (RS485 / RS232 / TTL)
userHead jbhan 2025-11-08 10:31:46 654 Views1 Replies
"When I connect the TTL port of the 'RainbowLink 4-channel USB to Serial Converter (RS485 / RS232 / TTL)' to an Arduino board (bluepill-stm32f103) via serial, the Arduino IDE recognizes the port but communication does not work. However, with a regular terminal program, communication with the Arduino board works fine. What could be the problem?"
2025-11-08 12:50:37
Was there a baud rate mismatch at the time of using it in the Arduino IDE?
userHeadPic ahsrab.rifat
